Hi
Just bought my self a 92 Mercury 50 hp (3 cyl) that not will pass approx. 2500 rpm.
Previous owner had it to a workshop,they took a compression test(all cyl. well),changed fuelpump,cdi-unit,
rebuildt the carbs,then the owner stopped them cause it started to be expencive.
Have set the ignition timing correct,so the engine runs really great at idle speed now.Fore some reason I dont now ,the workshop had put the timing way out.
I suspect stator faullt,understand that the stator on this engine has one low speed and one high speed winding,
is this correct?
Have measured the stator all way,every value is fine except between the two yellow wires that was connected to the
small type rectifier,value here(0.5 ohm) was 3 times more than the specifications chart says.
The stator has been replaced before I guess,partnumber is 174-9710 K
So I wonder,if using this 16 amp stator, I meen a voltage regulator/rectifier should be wired in somewhere,right?
This engine has just a small rectifier and output here is way to much(16-17 V) at idle speed.
Have not run the engine with load(out at sea) yet.
Could the wrong ignition settings cause this?
Do I need a new stator and/or a voltage/rectifier?
What should I do,anyone here that can help?
(Forgive me if the english is bad,am a Norwegian)
is this correct?
