Hello All -
I just purchased a 1985 60 hp 3 cylinder Mercury with manual tilt and no oil injection. I am in the process of pulling the lower unti and replacing with a jet unit. I removed the 4 bolts as instructed and the lower only dropped abiout 1/2 inch. I am not able to determine if I need to unbolt the shift shaft or if it is splined and simply slides out?
If the shift shaft is not holding the lower on, what is the best method of seperating? I've heard wooden wedge block, just wacking the lower, using straps to seperate?
Thanks in advance!
Jake
Thanks in advance!
Jake
