Re: Too much seafoam
Or you fouled your plugs from gunk that the sea foam loosened in your engine. Using the mix as your friend is called "decarbing" and the purpose is to purge the engine of harmful deposits that clog your engine and result in poor performance.
As mr 88 said, you probably dislodged some gunk in your carbs (which they apparently needed) and this gungie plugged some of your jets. So, it's time to do a carb teardown.
Don't blame the SF, blame yourself for not using it all the time which would have prevented this. Recommended ratio is on the can at 1 oz per gallon of raw fuel for injected engines or per gallon of pre mix for non injected.
Mark
