I recently purchase a 1971 Mercury 650 outboard. I have replaced water pump and oil seals on lower unit. When I bought it, it was in gear. Not sure if that matters or not but I will say when I had the lower unit off I put it back on with the lower unit in neutral. So now i am trying to install the controls and am having trouble with gear arm that is connected to the shift rod. Position of it right now is all the way forward. I can only move it back about 4 to 5 inches which it popped in to gear but not sure which one.
1. So the shift arm up in by the motor has a slot where the shift cable hooks up to it. Its about 8 to 10 in long. Should that be position in the middle of the slot before I hook my cable to it?
2. Would I need to drop the Lunit before I can move that arm freely?
Please help, any advise would be great thanks
Dan
Dan
