Re: 1977 Mercury Outboard 200 20 HP
With boat boat on a trailer, or the motor on a SOLID stand,
REMOVE the spark plug wires to ensure the motor cannot start.
Shift into Forward gear
Wearing sturdy shoes, no flip flops, step down on the prop and turn the motor over. You'll have to step on the leading edge of the blade on the Port side of the motor.
Does the motor turn over in direct relation to the prop or does the prop seem to 'slip' on the propshaft?
Another proven method is to scribe a line across the prop, from one side of the barrel (outer edge) across the nut to the other outside edge. Run the boat, then check your line to see if it is still lined up. If not, take off the prop, either replace it and call your local prop shop and ask what it costs to re-hub your prop.
If you can afford it, it is ideal to do BOTH, then you always have a spare good prop. A spare prop can save a weekend if you trailer very far and bang a prop, bolt on the spare and keep fishing.
