Duckhunter71
- Jul 31, 2008
- 17
Serial OT161xxx.
Blew a rod (#1) through the block. The 50 failed due to a rod bolt, don't ask how I know.....
I found a stripped powerhead from a 60hp. It had a scored #3.
I had the 60 block bored out 30 over.
I have new rod bolts for this project. I am going to go through the carbs I am going to verify the oil pump per the Merc manual.
I am going to use 2 stroke oil to lube while I build. Going to run 50:1 until oil pump verified.
Any other tips to make a success?
