Re: 1973 Mercury 40hp will not crank
I misread that. so the solenoid is working, just not rolling the starter motor. since the voltage is dropping to zero theres no "open" in the circuit..either the rebuild didn't take or the current isn't ample to run the motor. Im sure it's not the right way to do things but I would insure the ingition switch is off, take a set of booster cables and run one lead from the battery + terminal to the + input on the starter motor, momentarily. That effectively bypasses everything. If the motor doesn't turn, either the battery,or the motor is at fault, period.
