Ive got a (4351995) 1976 merc outboard 200/ 20 horse ....it has good compression 100 psi... both cyl... the motor has sat for 2 yrs... i ran fresh premium gas with the 50:1 mix as well as a Can of Sea foam... in 6gallon tank....almost noticeable improvement... any way now i cant idle at low speeds motor will stall....higher speeds are fine.... also i know noticed if i don't run the motor on premium gas it really runs crappy.... Help...
.... 1. should i try the air adjustment screws..
2. probly would be a good idea t get the carb rebuilt ??
3. Also i heard a rumor i need to have a vented gas tank at present mine isnt vented....
thanks for reading any other pointers are greatly appreciated...
