dOb
- Jun 14, 2010
- 244
OK, I've read and read about this and thought I had it figured out. But I don't.
I have a universal Kill switch. Four terminals on the back, two "C" and two "M".
From what I read, I thought that I should cut into the the "White" wire behind the ignition leading to the motor and connect the kill switch in line by the "M" terminals.
Here is the diagram I am using;
http://www.maxrules.com/oldmercs/Wiring/1966ona/26A.jpg
When I tried this, the motor ran no matter what I did. With the kill switch , M, C, no switch, cut wire and all. The key turned it on, and the key turned it off.
I would really appreciate some help with this.
BTW - I don't know if will effect this, but I did install a tach a while back. I had to get into the internal harness in the motor to separate the salmon wire and run the tach to (I think) the rectifier. The tach works. But I am wondering if that changes the way the kill switch would work.
Thanks
Thanks
