Replaced the impeller and works great, now i cant get the shift linkage to line up, when the lower unit is disconnected theprop spins freely either way so the unit is in neutral and i put the shift handle in neutral and once put back together cant shift it is very hard. How do i line up the shifting rod with the lower unit (there has to be a helpful trick). dropped the lower unit both in neutral and reverse not sure if that caused me more problems. Please help this is driving me crazy!!!
