Re: Mercury steering tube question
You can use PB Blaster sprayed on the tube with the motor layed on its side, so the penatrant will run down the tube. Then place a bolt of close to the same size of the cable end into the tube and try to turn the tube with a pipe wrench a little at a time while grinding the flared off while doing so. With the motor on the floor, or secured to a work bench, flat there is less chance of damage to the motor from falling and the weight problem should be of no issue. A little heat on the brackets might be needed to getting the tube to moving also. Once the flair is ground off and the tube has been turned, you should be able to pull it out of the bracket, or use a slide hammer to help remove it. JMO
Oldman570
