Does antbody know if you can use Stihl 2 cycle oil for outboards.
B bigbill64 Cadet Joined Nov 21, 2011 Messages 11 Jan 25, 2013 #1 Does antbody know if you can use Stihl 2 cycle oil for outboards.
JB Honorary Moderator Emeritus Joined Mar 25, 2001 Messages 45,907 Jan 25, 2013 #2 Re: Oil mixture for 4 hp mercury outboard It should be okay for air cooled outboards, Bill, but I would use only TC-W3 rated oil for water cooled outboards.
tazrig Lieutenant Commander Joined Dec 20, 2012 Messages 1,752 Jan 25, 2013 #3 Re: Oil mixture for 4 hp mercury outboard ^^^+1
quicktach Petty Officer 1st Class Joined Aug 24, 2012 Messages 394 Jan 26, 2013 #4 Re: Oil mixture for 4 hp mercury outboard Not if a conventional water cooled outboard. Follow manufacturer's recommendations. JASC rated should be on label. Use correct fuelil mix if two stroker.
