1979checkmate
- Jan 15, 2011
- 261
Hello all,
I have a 1979 mercury 115hp inline 6. A few years ago, i ran the motor with no water (water to the muffs got shut off - long story.) I caught it before the motor overheated and immediately replaced the entire water pump assembly, the impeller had melted and fallen apart. However, ever since i have only gotten a very weak stream/spittle/steam from the tell-tale at idle speed. A good stream develops if i bump the motor up just above an idle, and a very strong stream is present at all planing speeds. I feel like the water pump is pumping at the lower rpm's because i have never had the motor overheat on me and when on the muffs and the tell-tale just spitting, the water coming out the prop with the exhaust is luke-warm. However, it is still very nerve-racking for me when i look back in a no-wake zone and do not see the stream that i know should be there. Is it possible that debris is clogging the tell-tale at the lower speeds? Any way to clean out the entire cooling system of debris? I do pull the lower unit at least once a year and inspect/replace the impeller. This unit sees very little use (10-15 hours/year). I appreciate any help!
