Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Mercury 150 hp EFI Nitro
  • Mercury 150 hp EFI Nitro
    I just put in a new water pump and impeller in my motor. First couple of days it was pissing fine. Now it has stopped pissing I took off line and made sure it was clear Any suggestions
    Re: Mercury 150 hp EFI Nitro
    I don't know how that engine is plumbed. It may be off the stat output or off the top of the block. Apparently something has dislodged and clogged the hose. I would trace it back to the block and disconnect it there in determining if the hose is clogged or you are having problems with your water pump, or there is some crud in your bock clogging it, or your water tube and pump interface is no longer intact.
    HTH,
    Mark
    If you are new to boating or have a new boat, a knowledgeable friend could show you how to operate your boat and save you a lot of grief, maybe some money, and maybe your life.
    • #3
      I am wondering why I am not getting a hot buzzer alarm. I took off all the hoses connected and made sure they were clear. No water coming out.
      • #4
        Robin;
        What was the condition of the impeller which you removed? Were there any vanes or pieces missing from it? I have looked through your previous posts and nowehere do you mention the year or s/n. Do you have those?
        Gerry
        • #5
          Originally posted by carholme View Post
          Robin;
          Gerry
          Gerry it is 150 Hp Mercury Nitro EFI the serial number is OGO77344 the impeller was worn but no vanes missing. Looks like maybe some small chips. The metal housing the impeller was in was worn out. He replaced all that and it was pissing fin but I still had a oil buzzer alarm. Had another mechanic check out all the alarms on the alarm module. I had a cracked oil reservoir cap.no more buzzer but when I start the motor with the hose connection it will not piss. I thought maybe then thermostats were not opening so I replaced them. Still no pissing. So I took them out and still not pissing. I disconnected all the hoses and made sure there were no clogged lines. None were clogged but I did not check the hole that the lower hose came off of. Not sure if something is lodged in there. Still no pissing not sure what to heck next. Thanks Gerry
          • #6
            Sorry Gerry it is a 1994 Thanks
            • #7
              Re the one hose you haven't checked, get a piece of lawn trimmer line and shove it up that hose as far as you can or completely remove the line and make sure it is clean. You would not believe what mud daubers can pack in there and plug it completely. That is the easiest to do before you have to start looking inside.
              Gerry
              • #8
                Just an FYI, that serial number you posted is for a 175XRI not a 150. Check the powerhead on the starboard side for a core plug with the serial number stamped in it, and see if it says the same thing as the one on the tilt bracket.
                Don S.
                Please, no PM's (Private Messages) regarding boat/engine problems.
                That is what the forums are for.
                Only forum/moderator issues will be answered in PM's.
                • #9
                  Check your intake screens. When you put the lower unit back up, did the tubes line up and the neoprene connector seat and fit tightly ? Sounds like you may have to drop the lower unit and go back over your work. Did the impeller go in ok - could the blades have been bent in the wrong direction, then snapped off - plugging up the works? How about that tiny little key on the shaft that holds the impeller - I've had to hold them in place with a daub of thick grease while I fit the impeller over it ?
                  • #10
                    Don I will check. That is the number that was on the tittle when I bought it. But I will check the numbers and make sure they match. That could cause a problem ordering parts. I have ordered some parts already and they didn't tell that the numbers were for a 175 and they asked me what hp my motor was.
                    • #11
                      Quick tach I feel comfortable that he put it back on right. I was right there. But that is a good point. I think maybe the screens. The mechanic that checked my wiring said bigger motors sometimes don't get enough water with the muffs. The mechanic did other impeller back in the right way and lubed it. I kind of agree with on the screens.
                      • #12
                        From Mercury:
                        MERCURY - (175XRI H.P. (1994 ))
                        Serial No: 0G077344 Model No: 1175413PD
                        Parts Listing:
                        Mercury Parts, 150 / 175 / 200 XRI
                        The disc on the powerhead should look like this:
                        http://imageshack.us/a/img84/8224/391496208.jpg
                        Gerry
                        • #13
                          Don I checked again and my s/n is OG077334 not OGO77344 it looks like the OGO is OG and a zero not a O.
                          • #14
                            In my post #12, I did correct your s/n to a 0 instead of an O and that s/n is indeed a 175XR1.
                            Gerry
                            • #15
                              Sometimes its tha "Nitro" part that screws things up. They did some strange things when they went ta bed with factory rigged Nitro badges. ie: 200 hp XR6 Nitro!............
