Hi i have a 15 HP 1990 Mercury outboard that runs really good i can start it at the first or second pull. in neutral it runs fine but if i put it in gear it it will go in the slow position but when i speed it up it just runs the RPM's up and it will try to go but wont go more then 1-2 MPH. i cleaned the fuel pump because before when i would speed it up it would stall out. what would be the first thing i should look at?
