I get a single beep on blastoff and only during blastoff. The water pump impeller and gasket has been replaced by mechanic. It still alarms only during takeoff. I was told low water pressure would cause this. What should water pressure be at idle to takeoff? I also was told the wrong prop could cause this. I have a 20 pitch. Any suggestions? Also looking for a very good manual to do work myself.
