Re: 2005 Mercury 15 hp 4/stroke vs 1998
send me a PM with an email address and I'll send you a copy.
Gerry
Thanks for that very generous offer. Armed with the information you sent, I rolled the dice on the on line '98 Manual and it does appear to cover my engine.
I think this little engine -- which I bought with the rod visible through a hole in the bloc -- left the factory with a loose rod bolt. When I stripped the engine down today, I discovered a perfectly whole and unscarred rod bolt laying in the bottom of the case. its flat washer was nearby. The crank appears to be unscarred, probably because the rod is aluminum, not steel, and it is apparently plated with babit on teh big end, in lieu of shell bearings.
The other rod bolt was still in place, but was bent and banged around quite a bit.
I've seen plenty of rod bolts fail in engines of all sorts, but I have never seen one back out. he gonna get some red loctite if I fix it, and I think I will. It's a fresh water, very low time engine, judging by the lack of ccorrosion anywhere and the absence of carbon on the piston tops.
Thanks again for the offer and the valuable inforamtion.
