ok, so I took the carbs off my 1990 90hp mercury engine to rebuild them and while they're off I decided to get a flashlight and look at the reed valves.
they are the ones that look like a flower petal setup when you look at them installed. I'm trying to determine if I need to replace them or not.
the top carb set had 2 that naturally sit about 1~2ish mm from flush. are any reed valves that dont sit flush against the housing considered bad?
one of them also had surface rust on it.
I saw a couple more that werent exactly flush on the other two and the lowest set has some oil mix just sitting on it...which is why I pulled the carbs off in the first place to rebuild.
I would run the engine and shut it down and then oil mix would come out of the lower two carb throats and settle into the air intake box. when I'd crank the engine up, the carbs would suck the mix back up and the engine would bog down until it was all burnt and running on regular mix.
I'm just wondering if the reed valves should be replaced or how to tell when they're bad or not. I'm already in there so it wouldnt be too much more to replace them.
