My dad bought this engine almost new. It didn't get much use, and spent almost its entire life in a shed. It doesn't have more than 50 hours on it.
I decided I would see if I could resurrect it. It has great compression (115 in both cylinders), the carb needed to be cleaned out, and it had spark until I replaced one wire that tied the two (-) connections on the coils together. The wires that run to the coils are badly decomposed. I was able to wrap all of them with tape to protect them for now. The jumper wire that connected the coils together had 3 strands left. I found some similar wire, and made a replacement the same length. Now I have no spark if I connect that wire. Disconnect the wire and I have good spark on one cylinder.
Is there something about the length / impedance / material that I should know about? Or did Mercury just put magic in the wire?
I have the part number of the wire, but it's listed as Obsolete, so finding an exact replacement is gonna be difficult.
