donavonmercfreak
- Oct 23, 2012
- 4
Ok so i have a 1968 merc 100 hp that i am having issues with! When I start it with the muffs on its seems to run fine! when i start it up i have to choke it and hold key for a second but it always starts! As Long as i give it a little throttle it runs great, but if i leave it at idle, its seems to run for a while then just shuts off! Ok so heres my big question and issue! With the muffs it runs almost great i would say! It Starts up and runs at full rpms! sounds good as well! When I get it out to the lake it is a completely different story! It seems to take a bit so start, and when it does, it will only get up to about 10 miles an hour! (mind you it is on a 14ft crestliner) Even worse, when i use it(put it underload) at the lake it will go for about ten minutes and then just sputter out, and take a few minutes to get it started again! Motor has definately been taken care of....Looks great and is super clean! new plugs and wires and whole shebang! any advice and help is appreciated!
