D
Deleted member 340796
Guest
I bought a 1970 Caravelle CX176 Barracuda in May 2012 and started restoring it. On the Barracuda was a 1966 Mercury 65 HP 4 cyl that ran. It sounded good, seemed to power up and move the boat well. The only problem with it that I noticed was when it was in neutral you had to increase the power or the motor would stop running. I don't know a great deal about motors and less about marine motors but I am thinking that is not a real big deal (labor and time needed - yes).
Currently the boat is being restored. I have completed demo and have the new transom tabbed in. I am ready to start the stringers and ribs next. I moved had a relative in town so I took the opportunity to set the cap back on the boat, but have NOT secured it. I will still need to prop it up in the front when doing the stringers, ribs and deck in that area. We also moved the motor to a much smaller storage unit to save on the cost of storage. During this move the motor when hoisting the motor the top of the motor went to the left, with the prop going to the right and we noticed oil starting to drip from it. It only dripped maybe 4-6 ccs but I want to make sure that we did not do any damage by allowing it to tip a little. :facepalm: It did NOT tip all the way to a 10 - 4 o' clock position and really was closer to an 11 - 5 position. Please excuse my terms descriptions. Just want to be sure I have not done major damage to it with this move.
Also, I ordered on Ebay the shop manual for this make and model and expect to have it in the next week. I am hoping with the manual and some guidance from you wonderful people, I can get it drained and prepped for winter as I am going to be moving to Ohio in Jan or Feb. I will also want to make sure to check it all out along the way (whether now or after the move) and replace anything that needs replacing.
I am not your average woman. My grandfather was a mechanic that took me under the car for the first time when I was 8yrs old. I helped my other grandfather build an addition (bathroom) on to his house. I have changed out radiators, thermostats, water pumps and done other work on vehicles that I have owned. I am currently doing all my own restoration now with the help of Woodonglass, Trooper82, jbcurt00, decker83 and others. So rest assured, with you assistance I can do this. I just lack the confidence in doing it without some wise ones like you guiding me.
So, from the sounds of the slight tipping and oil dripping out, does it sound to any of you that I did any major damage or just experienced what you would expect with the motor tipping? I have read the link about winterizing your motor but am still waiting on the manual to guide me on the process. Are there things that are always needed when doing work on marine motors (certain tools, oils, lubes, etc) that I could start gathering to prepare for winterizing or doing an overhaul on it; or would you recommend I wait until the book arrives?
I am really looking forward to working on this motor, but I am also nervous because I don't have my grandfather any longer to bounce my questions off. If I were to start over in life, I would have been a mechanic. I like tearing things apart and putting them back together right. Looking forward to hearing what you all have to say.
Thanks so much,
AJ
Thanks so much,
AJ
