Im having problems with the motor stalling and bogging when u matt on the gas from a dead stop. It stalls like it is starving for gas. I can hit the choke and feather the throttle and will eventually get on plain and does wonderfull on topend and mid range. Motor also idles fine to. Just installed new stator, power packs and carb overhaul. Ive checked the fuel pump and diophram all seem to be workin properly. ive adjusted the carbs one full turn out and played with it and dont know what else to do. Ive also done a compresion test all are 126lbs. Please any advise would be helpfull thanks.
