Crazy Professor
- Oct 8, 2012
- 5
Hello Boaters!
When running this engine with hose attached, warm water only comes out of the vents at the bottom of the leg not the small hole on the rear right of the power head, or the two ports at the lower back part of the power head. Is this a problem? What should i look for? I have never run this engine in the water as yet. I have already inspected the impeller and found it intact, but with some wear on the outer edges of the impeller vanes. I forced water up the cooling system tube inside the leg that connects to the water pump, with the same results.
Thanks for any help in advance.
God Bless
God Bless
