I am trying to change the impeller on my engine. I have done it myself in the past. My problem is I can't disengage the lower unit from the rest of the engine. I have removed all bolts EXCEPT the 2 bolts on each side of the engine. I have loosened these bolts so the lower unit won't drop off. I have removed the bolt that connects to the trim tab.
I kept the engine in neutral. ( no problems in the past. The shifter is in neutral and the prop is in neutral. I can turn the prop freely either way.
This engine has only been used in fresh water. I have used a block of wood and rapped the lower unit on all sides. it doesn't seem to want to give.
Any ideas????
Sullmate
Any ideas????
Sullmate
