I replaced the seals on this mercury 90 hp 4 stroke (2001 model). I have the service manual, but the pictures of the shift cam do not look like mine. After I put the lower unit back together and re-installed it on the boat, shift pattern is backward. When I shift in forward, the prop goes in reverse. When I shift in reverse, the prop goes forward. I wonder if I put the shift cam in upside down, which would reverse the forward and reverse locations. Is there any other possibility to predict this behavior?
Bpboater
Bpboater
