Re: Mercury Mark 58A timing gage
I have use a timming wheel for a motorcycle engine to set and check the timming of some outboards. If there is a cycle shop near you they might have one you can buy or run it thru a copping machine and get a print out of it in real size and be able to use it to transfer the needed marks onto the outboard flywheel if it dose not have any that are visable. JMO
Oldman570
