Mercury 2005 150hp Optimax the motor trim runs down on. The tilt and trim motor will run down on it on and stay on running. You can push the trim button up and the motor some up and when you let off the switch it running back down and stays ruining. Check the two relays and swamped them out still does it. Guess the only thing it can be is the tilt and trim motor is bad? Anyone else have this problem? And is there anything else it can be?
Thanks
Thanks
