If anyone remembers, I am still chasing down that rubbing noise that I posted on Sep,20th, I have tried all the suggestions with no luck. I think it might be a crank bearing, I would like to know if anyone has replaced those bearings without pulling out the crank? On my spare motor for parts which is the same motor I have removed the bottom bearing carrier and can see the bearing fine? I haven't pulled the top bearing carrier and was hoping it will come off the same way. Any help would be well appreciated, I will try to post the most recient video as the noise is getting a lot worse. Thanks Buz
