I bought this boat about a month ago and it's been making a concerning noise.. I didn't notice it when I test drove the boat, but I was probably so excited I simply didn't pay enough attention.
Here is a clip I made yesterday.
(Please excuse my aussie accent, I hope you can understand me )
http://www.youtube.com/watch?v=0xtHwZUPivU&feature=plcp
It mostly does it when I'm just below planing speed and putting some load on the motor. However, as the clip shows it'll also do it in neutral as well. It doesn't do it at idle and it doesn't do it when I'm at cruising speed or WOT.
Whilst on MUFFS today I held a screwdriver to my ear and against the engine beside each of the cyls (beside spark plugs) and there doesn't appear to be any foul sounding noises. But again, the knocking noise doesn't happen on muffs regardless.
I followed this guide and there was no play whatsoever - http://www.youtube.com/watch?v=bgfgbpvOFrQ
I have been running 50-1 Valvoline and Mercury 2 stroke oil. Plugs look healthy, though I replaced them today just to be sure and will water test the motor with them in tomorrow.
Compression is 125, 125 and 123 (can't recall which cyls spat out which readings).
Engine starts fine and top speed is about as expected, just shy of 30 knots. Boat is an aluminium 13.5' with full floor, front and rear casting decks, bow mount electric, battery that runs the sounder/nav lights and a deep cycle for the bow mount. The prop is well worn, so I expect some more top end speed once it's replaced. Hole shot is rather excellent.
There is another sound that happens within a certain rev range right before WOT. It's almost like someone has suddenly put a hole in the exhaust.. hard to explain, but the motor becomes noticeably louder before going quieter again once I get closer to WOT.
Any and all help greatly appreciated. Unfortunately I can't really afford to pay a mechanic to look at it at the moment.
Cheers from down under.
Matt.
ps: Here is another clip I took where I removed plug leads to make sure it was running on all cyls.. Was hard to tell actually. - http://www.youtube.com/watch?v=hk0aon9HZaY&feature=plcp
EDIT: New video http://www.youtube.com/watch?v=iNl3ofJwqqY
Matt.
