I just picked up my first boat the other day with a 1980 60HP 2 Cylinder Mariner on it (motor looks like an alien head). The boat is a fiberglass 15ft TideCraft V-15 rated to a horsepower of 100. Engine has 130 psi compression in each cylinder, good spark on both plugs but the prop is pretty dinged up. Not sure the pitch or diameter of the prop yet. I took it out the other day with 6 gal of gas, 2 batteries, some other misc small stuff and it got up to 28mph with just me on board (170lbs) and only 26mph with me an another guy (170 lbs). Is this about the top speed for this motor and boat combo? What would be the right pitch and diameter prop for this motor?
The boat does not have a tachometer and the motor does not have power tilt/trim, but I can change the tilt angle manually on the trailer using the 4 notches on the motor. Any help is greatly appreciated.
