lippreaper
- Sep 20, 2012
- 2
My 1998 Mercury EFI 200 HP outboard started making a chattering noise when its at idle. Its not a constant noise, it goes in and out of this randomly. Sometimes it doesn't do it for a while and then it will for a few seconds. Other times it just goes in and out of this noise quite frequently. Before my last time out on the water I checked my flywheel nut and only got about 1 turn out of it, but I didn't wrench down on it to hard cause I didn't want to cause any issues if thats not it. It didn't help... The best way I can explain the noise it makes is chattering/rattle not an engine knock. I can't hear it when I have it out of the water with the ears and hose because the motor is to loud. Other than this noise the thing runs like a top, any suggestions?? Oh and new water pump and prop hub kit was installed 2 months ago... Any info would be much appreciated. Thanks in advance!
