Hello,
this is my first post. I recently bought a 1983 16ft boat with mercury thunderbolt ignition 50hp merc. I first noticed a fuel leak when the outboard was lifted up for towing. I researched this and that seems to be normal, however when tche outboard is down and has even ran for awhile ( it idles fine ). after shutting off there is still some fuel coming out of the air horn ( where the choke blade is ) and leaking down the shaft on the backside of the carb. I dont believe this is normal.
this is just on the lower carb. Before tearing into the lower carb I wanted to verify that this is not a normal/nature of the beast condition.
Thanks
Thanks
