Re: 80 hp mercury no fuel
if you put your hand over he carb and trhe engine is there suction? and after the suction you feel back flow pressure sort of like compression coming out of the carb. Im thinking if gas is puking out of the carb you may have a broken reed valve. Check you transfer case plate and make sure it,s tight.
