Hi There,
I'm in the UK and don't have too many people around to ask for help so heres hoping one of you can help. My engine runs fine and when I push forward or reverse on the Quicksilver Throttle lever, the gears engage correctly. The problem I have is when I click into forward and push the throttle forward, the engine just stays at idle until the throttle level is nearly at the end of its travel and coming in very late to accelerate. Looking at the throttle arm on the engine, I can see the gear remote engage and the throttle arm is definately coming in late. I think that I probably have an issue within the Quicksilver unit but I am not sure if I can get into it to make adjustments of any kind. What do you think ?
