I picked up a 1971 Merc 650 for cheap ($125) the lower unit had "something" happen in it, that's what P/O said (didn't hit anything he thought). The case in cracked near the back. I would like to pull the parts out, what should I look for as far what could be damaged/broken? I was able to pull the prop shaft and carrier out the nut fell out because of the crack.
Thanks,
Thanks,
