According to my manual when changing oil in the gear case you fill it untill the oil comes out both holes at the top then put all three plugs back in. On an older Mercury 90 HP (1985) I had it said to fill until the oil came out the top hole then let an once or two drain out before installing the plugs, to maintain an air space for when the oil heated up so the seals did not blow out. I'm just wondering if this air space is not necessary in the Optimax. Maybe they have a vent to prevent pressure build up?
StanH
StanH
