Hey Guys
S/N 0T514288
Problem happens when I hit between 2000 and 2600 RPM. It fluctuates at where it begins from test to test. Boat refuses to get on plane. Giving more throttles produces nothing but a slow rhythmic shutter, but it wont stall unless you really try to punch it.
Checked Compression, good across the board- on trailer and under load.
Checked Fuel pressure- Steady 36psi on trailer and under load all the way through issue.
Checked Spark- No issues on all six wires on trailer and under load all the way through issue.
Bulb is tight. Back-flow prevention valve replaced this summer, no issue. All filters and water separator clean.
Spark plugs replaced this summer.
Tried the trick of disconnecting the temperature sensor, no change.
S/N 0T514288
