gleaseball
- Sep 3, 2012
- 1
I recently replaced the water pump on my 1991 Mercury 150 Outboard. The replacement went well (pulling the L/U, etc.), but when I started the motor up I could not shift gears out of Forward (unit was in forward with the L/U was pulled). Linkage is fine. Even when I disconnect linkage and adjust gear shifting by hand at the motor it does not click and does not seem to have any affect. Not sure if this has to do with the drive shaft or what. Any advice would be appreciated. Engine will start, but obviously it is stuck in forward.
