Mercury outboard 2-stroke 4-cylinder, 40 HP
M/N 1040302TD
S/N OG-475927
I had tried to rebuild the lower carb. without service info. After limited success in adjusting it, I'd like to take the good advice in several threads to get a manual. Unfortunately, every one I've run across seems to have differences with the WMA carb. I'm working on, so I can't be certain the info. is valid.
For instance, these WMA carbs. do not have integral fuel pumps.
M/N 1040302TD
S/N OG-475927
