I am in desperate need of a 1965 Mercury 900 90hp 2Cycle Straight 6, External wiring harness. I am lucking out all over the United states If you know of where I may find one or where to try looking for one
Scarce and you would be lucky to find one, If you have the inside plug, why don't you build your own and ensure that you won't get something with the corrosion already built in.
I was told by the marina that is doing some work that there was no way to rig it or wire it without the harness, i found one simular on ebay could you please tell me if this one will work. Go to ebay then type 180773693039 thanks so much hope you can help me out!
