I just pulled my boat out of the garage after sitting a few years, cleaned everything, new gas, replaced some cracked wiring, replaced the impeller and all the lower end seals. Motor fired up and is running. I cleaned the carb as best as I could but it has a rough idle, I was messing with the idle adjustment and forgot where it was set, now when I put it into gear it will bog down and die! Ooops. Was at least running in gear prior, the idle is still a little rough as well.
Ive searched and searched but cant find any info on the idle screw adjustment. How far out should it be set? What will get me in the right range to fine tune it? Could it be the high speed jet adjustment?
Thanks for the help!
Mike
Mike
