Am looking at buying boat with 1996 Mercury 150 EFI. I previously had a boat with this motor and it performed well.
The seller of the boat I am looking at has owned the boat since new. He said that 2 years ago, alarm sounded and motor started running rough. He took it in and was told the oil injection pump had stopped working. Technician recommended he remove the oil injection and mix the oil when adding gasoline. He agreed to this and oil injection was disabled or removed. Oil tank is still there. He said motor has performed well since then. I understand this is often done on these engines and that some owners prefer this as a sure way to know that motor is getting oil.
My concern is this: When I turned the ignition switch one notch to "on" (not crank) position, I did not hear the short beep to let me know the alarm system was operational. With my previous 150 efi, I always heard a short beep when turning on the ignition switch. I understand the alarm is not needed to warn of lack of oiling if the oiling is disabled and fuel and oil is mixed.
However, I do want to be sure the alarm is working to warn of engine overheating.
How can I be sure overheating will sound an alarm?
And, how can I be sure the alarm is working every time I start the engine?
And, should I be nervous about buying a 96 model engine that has the oil mixing disabled and no start up alarm?
Any other advice for what I should look at on this engine before buying would be appreciated.
Thanks.
Thanks.
