dustinjohnson36
- Aug 5, 2012
- 1
I read and searched tons of threads the last couple of days trying to figure out my problem. I wasnt able to find exact issue so im starting a new thread.
Heres my issue- My outboard will fire right up on muffs, idle fine. But when I put it in the water and push the throttle the motor loses all power and stalls out. Heres some things I have checked, I pulled each of the bottom plug wires while running and the engine stalls out. When i pull the top two there is no change in the motor. Another thing I check was the bottom card has nice suction and the top carb has no suction. So im assuming it has something to do with the top carb. Whats your guys thoughts? Fuel is fresh, primer bulb is nice and tight, lines are clean. Ran sea foam through it couple days back hoping to clean the carbs out.
Thanks
Thanks
