1986 mercury 60 hp leaking oil??
1986bassbuggy$@
I have an 1986 60hp merc 2 stoke outboard that always has a half dollar sized oil spot after firing it up and it's cooled, it is leaking out of the exhaust in the center of the prop and it's very black. Is this a gas mixture or carb issue??
aussieflash
Re: 1986 mercury 60 hp leaking oil??
Are you sure its not lower end oil (prop shaft seal).Let a little oil out of fill plug on leg and check for water.
1986bassbuggy$@
yes sir checked that full to the top it looks more like burnt oil it's jet black. now this motor will not reach WOT with out bogging down under a load, on muffs it's fine didnt know if that helps?
aussieflash
Maybe just some unburnt fuel mixed with carbon/exhaust dust that separated/evaporated leaving a dirty oil appearance.Thats my best scientific guess.
Bogging under load could mean a stator check/ignition tests,or a fuel problem/dirty jets etc,or maybe fuel pump.
1986bassbuggy$@
Well it will not start unless i squirt some fuel in it then its fine, still new to boats where is the pump located?
