Re: oil induction removal
There is more involved to disconnecting the oil injuction system on your motor. The easiest way is to buy a T fitting at the local auto store and place it in the oil line from the tank to the oil injuction pump, then take the oil line from the oil pump to the fuel pump and put it on the T that you put in. Now use a peice of hose or a vacum cap and plug the fitting on the fuel pump where the oil line went to. By doing it this way the oil in the tank and lines will just be recurlatede and all the parts will still be there if you want to trade the motor off or reconnect the oil pump system. Parts for the oil injuction system are very $$$, and most dealers will not take the motor in on trade if the oil system is missing. JMO
Oldman570
