I have had this boat for over 6 months now, I have ran the water numerous times with no problems at all. Starting about a month ago , I would take the boat out and I could get on top with no problems, but with in minutes the motor would bog out, and loose power, it would run about 7 mph and turn 3000 rpm. If I just leave my foot on the peddle there will be times about 10 minutes later the motor will kick in and start running great until I turn it off. I will check the compression and the spark after work, but I am wondering if this may be power box(s) or stator? any advise would be greatly appropriated before I go and break out another thousand!
