swordfish69
- Aug 5, 2012
- 2
Hello all,
I've just purchased a 12' auminium run about that has come with an old, aircooled Mariner/Yamaha 5hp outboard.
Serial #: 661S 034376
The engine is in reasonable condition for a 30+ year old motor, good spark, compression etc. Issue is it appears to be stuck in FWD gear and cannot be changed into reverse. I am trying to remove the lower unit (gear box) to investigate further but have run into a spot of trouble. I've removed the bolts holding the LU on (3 ?) and disconnecteed the shifter rod. A small crack has opened up between the LU and main assembly but I cannot seem to remove it any further. Any insight or suggestions would be greatly appreciated. I can post photos up if that would help.
Thanks.
Thanks.
