I have scoured the forums and have found different answers regarding timing marks on an 850. Attached is a picture of my timing decal. I replaced the trigger and the flywheel was originally set at the three vertical marks being TDC. However, there is a larger mark to the left of it that says TDC. Which marks should actually be set at TDC?
Thanks,
Dan
Thanks,
Dan
