Thread size for "standard" or most hydraulic steering hoses?
rdranman
So, I am in the process of replacing all of my old mechanical/power steering with a new non-power hydraulic steering system. This is for a dual station setup. Rather than using nylon hose with compression fittings, I am looking to use pre-fitted outboard hydraulic hoses to minimize future leaking issues. The question is are these a common size on the connections (e.g., 3/8 in with 9/16in-24 threads)? Because of the dual station, I need to get T-connectors to tie 3 lines together. Thanks.
Charlie61
Re: Thread size for "standard" or most hydraulic steering hoses?
no they are not common size , if you can take parts with you or the something that work the same before are buy. it will make for a lot less running to supplier
