Shallowman
- Oct 11, 2010
- 114
Decided i'll have to try to fix my motor myself , looking online i find its either a 1983 or a 1984 depending on the site i use . I need to know what year as i want to make sure i get the right parts ( water pump kit and trigger assembly) SN is 6463016 . I found a Seloc one that covers 1977 to 1989 ( thou it says there is no 83 60hp 3cyc ) So iam guessing the site that shows 1983 is maybe not correct . Are soloc books detailed enough or is there a different company to look for a repair manual for ?
There is no water out the pee hole , i checked the hose and its not blocked . Any thing else to check and if i need to replace the impeller , should i do the impeller or just do a whole kit ?
Will the repair book show what the wires are for on the quicksilver plug ? (the small 6 prong one , that comes out the front of the quicksilver )
